Hose repair ???
MVCP 09-07-2008
Hello everyone!
 My 3" discharge hose coupler is worn thin on the inside. Does anyone have experince with having a new end installed or do I skip that and buy a new hose. The rubber seems fine. it's a Con Form product.
typesdubs 09-07-2008
Buy a new hose
mohd 09-07-2008
buy a new one
scolew 09-07-2008
The un-safe factor is to high. Like i have been told so many times, and I quote," Don't do anything that will make you loose sleep at night"!!!
TooTall 09-08-2008
BUY A NEW ONE! there's guys that try and fix'em like you would fix yer agua hose with a big ole ribbed insert and some big band-its. How long does a "Fixed" water hose last on a pump?..There's your answer.
There  should be no-such-thing as Disharge or Delivery hose repair!! Being cheap hurts poeple!!
Vasa 09-08-2008
If you are sure that the rubber is OK , take a pressure test of the hose....Does some company testpress their hoses in USA ?
Have ACPA some guideline for that ? The Swedish "CPA" working on guiedline for that , they talked about it on the last meeting I was at .
And let a workshop ( we go to our hydraulicworkshop) that press new coupler on the hose , press a new one , not a screwclamp !
