Schwing | 05-01-2015 | comment profile send pm notify |
You might be surprised to learn the Schwing SPTO 4000 carries 500 feet of system with ease! Check out these photos of a stock machine we loaded up last week. 300 feet of 5’’ pipeline - 15 sticks per side 200 feet of 4’’ and 3’’ hose Plus all required clamps and reducers With full fuel/full DEF and full water the unit weighed 13,900 pounds on the front axle and 20,700 on the drives. The 2023H-6 Twin Circuit Pumpkit with Axial Bearing M Rock is rated at 182 yards an hour with 1233 psi on the concrete. The Mack Granite GU 812 has 365 HP. We’re ready if you are! Call for a quote! 888-SCHWING |
PUMBO | 05-02-2015 | reply profile send pm notify |
Great pump setup, but not to disrespect your setup, what possible advantages a long nose truck cabin chassis have over a flat cabin in this application? |
Vitulla | 05-02-2015 | reply profile send pm notify |
we don't have any flat nose options that make sense $$$ wise for line pumps. A Mack is way too expensive for a line pump, so we fall on conventional cabs. Kenworth is suppose to be putting bigger transmissions on their K series, but not sure when that's suppose to happen |
PumpKid_88 | 05-03-2015 | reply profile send pm notify |
we run 200 foot at all times of 2in if the job calls more then we shall load more line or even size line we call for |
