Hypro Pump Siezed up...
Derputzmeister 01-17-2008
Thought I'd pass this onto anyone that may have replaced their water pump with a Hypro pump.
I replaced our main turbine fan water pump with a Hypro pump (per recommendations from Bob) this past early summer.  I didn't realize that it needs an occasional lubricating as well as winterizing during the freezing winter months.  I shot some 15-40 oil into it along with some anti freeze, it started working and runs great again.  The Hypro doesn't have a drain plug so, I put a "T" into the pipe on the suction side, with a plug to shoot anti freeze into it after winter jobs, also I can squirt some oil into it for lubrication periodically.
Bob 01-17-2008
Do yourself a favor and take off the end plate (don't drop those screws) and eyeball the rollers. It will only take 15 min's and you will be wiser afterward.
Bob 01-17-2008
ps
use some gasket sealer when you put it back on ;~)
typesdubs 01-17-2008
We steal some air from the tank with our water hose and gently blow antifreeze through all of our lines and water pump when it's close to, and below freezing.
Not only have I done that Bob, but I took your advice and ordered a repair kit with replacement rollers.....  :-)
http://www.hypropumps.com/en-us/Products/Pumps_Summary/Roller/7500/7560-GM30_Model_Detail/7560-GM30_features.htm
Seed 01-17-2008
Bob Rules!
Bob 01-17-2008
Have you changed the rollers yet?
u-crack-me-up Seed
concrete animal 01-19-2008
LUBE?
Derputzmeister 01-19-2008
Bob, haven't had to change the rollers yet, they were just siezed up and needed lubricated.  The owners manual for the pump says to periodically use a oil and a lubricating anti-freeze, which freed up the rollers and it works fine again.  I suppose they will need to be changed some day.....
Bob 01-19-2008
I am quite surprised that the rollers have lasted this long. Don't let them get too small as they wil chatter which causes wear on the housing and end plate. The good thing is that even if you froze it solid and killed it you would not need to sell your house to buy a new pump. Sometimes, cheap is good.
cifa36z 01-20-2008
out here we use hot water in the winter months that has not been good for the rollers seems to soften and disfigure them
Bob 01-20-2008
Cifa z
What style rollers do you use in yours?
