| Todd | 06-15-2013 | comment profile send pm notify |
I was not there and do not know for sure but that is what I was told be someone on the job. |
| Mister_Perkins | 06-15-2013 | reply profile send pm notify |
That doesn't look like that happened because it wasn't level ... that's just my opinion though. |
| Todd | 06-15-2013 | reply profile send pm notify |
We you might be right but that is what i was told but who knows really. Time will tell. |
| pumpjockey | 06-15-2013 | reply profile send pm notify |
Unstable dunnage (too high? - not enough footprint?) , parking brake not set? Fortunate nobody killed for sure. |
| Weave | 06-15-2013 | reply profile send pm notify |
Looks like the ground settled when he flat sticked out and it slid off the plastic pads. |
| rusty22 | 06-15-2013 | reply profile send pm notify |
I would say both dunnage and pump were not level.Look at the left front dunnage pile |
| JoelDLong | 06-15-2013 | reply profile send pm notify |
trim pipe get hung up in wall while laid flat out ?? |
They are the best pic's of a accident.You can see all of it. |
| Z-Boom_Parks | 06-15-2013 | reply profile send pm notify |
Just by looking at the last picture I'm wondering if the dunnage and pads for the front weren't level and the legs where sitting on a decline slope. With the boom fully stretched and full of concrete that may cause the pump to lean and slid forward. Redi mix truck might also have bumped the rear of pump and in combination with the decline sloped pads may have casued a slip forward as well. Quite a shame, thankfully no serious injuries. |
| bisley57 | 06-15-2013 | reply profile send pm notify |
The walls were kicked off using crane mats.......the pump drove to his set up on crane mats..............Why weren't crane mats put under the outriggers? The pump is between a roadway and pond/lake.......obviously poor planning |
| The Punisher | 06-15-2013 | reply profile send pm notify |
Word is, passenger side wobble foot set on slanted pads, weight hit when stretched and pumping and walked it off of the pads. Seen this happen a couple of times with wobble feet |
| bisley57 | 06-16-2013 | reply profile send pm notify |
So why werent' crane mats used under the outriggers? Priority #1-your own safety Priority #2 others safety Priority#3 meeting the contractors "schedule" |
| Schwing31ht | 06-16-2013 | reply profile send pm notify |
Never used plastic pads on plastic pads... woods and plastis it's ok but no more for best result used only wood and watch out on ice guys |
| Weave | 06-16-2013 | reply profile send pm notify |
Opened mine. Done stupid setups on occasion. I'll forward this to the guys i work with. |
| Many | 06-16-2013 | reply profile send pm notify |
Another good example of why big booms need oilers.That extra experienced set of eyes just might have helped.Sorry to see this one happen |
| Beast | 06-17-2013 | reply profile send pm notify |
plastic pads , with swivel feet on outriggers are a recipe for disaster, unless the pads have a counter sunk hole for feet , they will slide off these pads ! Man I have seen seasoned operators do some not so safe set ups , not to long ago , after he had a accident , showed up and was doing exactly what happened here, I moved and relocated the pump to a safer location, bad things happen , even to experienced operators. When you get comfortable thats when accidents usually happen, respect these machines and the dangers !!!! |
| Mister_Perkins | 06-17-2013 | reply profile send pm notify |
Beast Said it. being comfortable is very dangerous. You should always be a little nervous even if you know the machine in and out |
| ShortStik | 06-17-2013 | reply profile send pm notify |
IMO from looking at the pics --- bad ground, pads sank to the front. before the pump fliped, the rear tires lifted off the ground or already were, so no tire brakes to help stop the slide. pump slid forward on the stacked plastic pads.
shitty to see these pics but i learn something from them. |
| Dont need one | 06-17-2013 | reply profile send pm notify |
Not a pro, didnt read the post's but have heard Putz'ys walk off pad's when rocking or shifting. But still not a pro. Hey AZ Pumper how youy doing. |
| Beast | 06-19-2013 | reply profile send pm notify |
I ran a 58 for a while and we custom made aluminum 42" x 48" aluminum pads, they was heavy 260 pounds per pad , but well worth the extra effort. |
| putzman1975 | 06-20-2013 | reply profile send pm notify |
barking brake had to be on or pump will not go into pto i ran a pump like that so i know brake was on |
| Mister_Perkins | 06-22-2013 | reply profile send pm notify |
even if your parking brake is on, the front tires still will spin. It only locks the rear tires .... |
| putzman1975 | 06-22-2013 | reply profile send pm notify |
true m p but still wont go into pto without brake on |
| AZ pumper | 06-24-2013 | reply profile send pm notify |
Unfortunately this was a piss poor set up or a bad job check I am sure we have all been in a situation that we should not have been in. The key is to learn from it. |
