ICF Placing tools?
kid 02-06-2009
It is hard to follow the no steel on the tip hose rule when the company you work for supplies a steel s-tube and squash pipe to run on a double ender for ICF/styrofoam walls. This is common practice and what we have been trained to use for this type of pour. This is also what are customers want to use because a straight flow puts to much presure on the styrofoam blocks. I have used this S-tube type reducer a couple times and I am looking to retire it from my collection of placing tools. What does everyone else use for this type of pour? Are there any alternatives that can be purchased?
CAPTAIN VIC 02-06-2009
We reduce down to 3 inch and use a 10 foot one ended hose. Having steel on the end hose is very dangerous. Head injuries from a whipping placement hose can be fatal.
Please consider what most operators in the United States are doing. NO STEEL ENDED HOSES or "S" pipes suspended from one.
kid 02-06-2009
I am aware of the dangerous consequences that occur from using steel on the tip hose. I am 100% in favor of not using steel that is why I am asking your advice. We recently recieved the new hard hat stickers in the mail and most of our operators cant evon ware them because they know if they are asked to use this steel divice they will. I find it funny that some guys put them on there hard hats evon though they are still going to use this S-tube/squash pipe. The main problem is that evon are managment/disbatcher uses this device the odd time he goes out on a pump.  How do I being the low guy on the totem pole put this rule in motion? When clearly there is nobody obove putting this rule in place.
Bob 02-06-2009
Here is an idea that beats the hell out of
using the old twin 90s. Do a little searching
back in the older pages. These were from
pages in the 30s.
DO NOT USE TWIN 90'S - TELL YOUR BOSS !!!
Have him call me, I would love to speak with him
Bob Sanderson (770) 403-1444
traffic cone
this user is offline now  Kris Leers 11-23-2008 02:38:16 reply | profile | send pm
Member
Here is a detail picture I've just made. I don't know how to put more then one picture on the message board but you can check out more pictures on my website: www.concretepumps.be (pictures of cone under "Safety")
this user is offline now  Pump N00b 11-23-2008 04:22:40 reply | profile | send pm
Member
Woho! In norwegian also!
So you just strap it to the hose with that belt thingy, it does'nt come flying off when you pump fast?
this user is offline now  Kris Leers 11-23-2008 04:48:50 reply | profile | send pm
Member
The cone has got two half rings inside with which fit in the ring of the hose. The strap is just to keep the two rings together, the rings are locked on the ring of the hose to prevent the cone from coming of by the force of the concrete flowing out. If you pump faster, the cone opens because I cut slots in the side. However, if I have a pour with big quantity of concrete I don't use it because the hose is filled up with concrete completely if you pump at high speed and there is no concrete splashing.
this user is offline now  Kris Leers 11-23-2008 04:52:53 reply | profile | send pm
Member
this user is offline now  WHO?? 11-23-2008 08:10:23 reply | profile | send pm
Member
Quick question ....Does this attach to a Double ended hose???
this user is offline now  Kris Leers 11-23-2008 08:25:18 reply | profile | send pm
Member
Yes, I attach it to a double ended hose and put a rubber hose over the metal parts to keep it safe.
You could also put it on a single ended hose if you carve out a strip in the rubber from a few mm. This way the iron ring on the plastic cone can fit in to prevent the cone from coming down.
I've put a video on you tube as well: http://www.youtube.com/watch?v=kHeJ_PyKe9A
this user is offline now  TooTall 11-23-2008 12:04:11 reply | profile | send pm
Member
This is a good idea for Quadlock or styroform walls that require consistant flow and is a better alernative than a dangerous double 90 flow control. In the US hanging a double end hose is a big NO. Most contractors wont have it and profesional concrete pumpers dont even consider it. Simply covering a metal end on the discharge hose does'nt make it more safe, but it might reduce Blood loss a little.
 Your cone is probably safer than the fools that do this.....
this user is offline now  TooTall 11-23-2008 12:14:55 reply | profile | send pm
Member
this user is offline now  Kris Leers 11-23-2008 13:23:18 reply | profile | send pm
Member
Too tall, I agree with you about the metall on the end hose. Too many people got injured or even killed from uncontrolled hose whipping. Over here most people work with a 100 mm end hose end a lot of them with double ended hose.
A few years ago a collegue of ours lost his live. He was listening on a double ended hose for the concrete to come when he started pumping. The hose blocked up, the pressure raised and the blockup released with enormous force. He got struck by the hose in the head...
I searched for a system that is safe and still keeps the clients satisfied cause if the concrete splashes all around you don't have to come next time.
I use a 125 mm end hose. There is no reducer on the boom so blockups don't often occur, especially not if you compare it to the 100 mm hose. If there gets a big stone in the cone it will open. If the rubber cover on the metal parts is thick enough it will proctect from injury. Putzmeister have got a system where they put a reducer on 3 metal pins and cover it with rubber and a system to cover couplings with rubber: both are aproved by the german Berufsgenossenschaft concerning safety on concrete pumps.
However, it's possible to use the plastic cone with a single ended hose as well and of course, no metall at all is safer then metall covered with rubber.
this user is offline now  Pump N00b 11-23-2008 16:31:15 reply | profile | send pm
Member
The Putz system works great, well, when its new that is.
My experience is that it wears out fast, and they get 'soft' somehow.
So you end up with a bunch of halfworn equipment that is got for one type of concrete and not much else.
Perhaps it's something with the concrete here in Norway, I don't know.
Just my experience.
If you haven't had the chance to test the Steady Hose from Putz, you should do.
I was pumping flat out on a 42m putz, got a rough mix i guess and got a plug.
The plug got free and the hose just hung there, no swinging or whipping, just like nothing happened.
Good stuff.
this user is offline now  Kris Leers 11-23-2008 21:07:17 reply | profile | send pm
Member
When you were pumping with the Steady Hose, was it 125 mm or 100 mm?
this user is offline now  Vasa 11-23-2008 22:10:36 reply | profile | send pm
Member
I use the steadyhose (100mm) and it works very well ! Hardly no whipping at all and it is so light !
this user is offline now  Kris Leers 11-23-2008 22:18:01 reply | profile | send pm
Member
Sounds interesting. Why is it so light? Isn't there steel wire inside?
this user is offline now  Vasa 11-23-2008 23:17:34 reply | profile | send pm
Member
I think is some kind of "textilfibre" or composite fibre.... But it works well , if You pump without a hoseman and it hangs free it is more steady .
I will do a "traffic-cone"  to My 5" endhose and test it ! Lokks good !
this user is offline now  Bob 11-23-2008 23:32:51 reply | profile | send pm | delete
Member
The traffic cone is an interesting solution to a problem. The way it is configured – with a two ended hose is not acceptable at all. The way it is configured goes against our stand of NO METAL on the discharge hose.
When this or a similar device is put on the end of a single ended ANTI WHIP hose, then we might be closer to a way to not only stop the hose whipping but the splatter and control problems as well. Our inventor needs some help to tune up his device.
It sounds like VASA is going to do just that. Hose manufacturers are the ones that should be doing this research
Good luck V, and be careful out there ;~)
this user is offline now  Kris Leers 11-23-2008 23:59:28 reply | profile | send pm
Member
Bob,
I've got already a solution in my head where no metall at all is involved. Will work it out as soon as I got the time and post some pics.
I agree totally with your point of view on double ended hoses. We can't be carefull enough!
On the other hand, if the German association for safety has aproved the Pin Pour system from Putz, they must have tested it very well because I know those Germans are very strict on safety rules.
Even a single ended hose is still steel wire covered with rubber...
If the single ended hose gets blocked and the pressure releases with a power of 10 Ton, the impact will be almost as destructive.
Anyway, the safer the better. I will work on it till I find a solution that meets the requirements.
Bob, I think it's great what you and all the others do to make our industrie more safe. By sharing our experiences we can avoid a lot of damage and find solutions to problems related to concrete pumping.
this user is offline now  Vasa 11-24-2008 00:15:42 reply | profile | send pm
Member
Bob I have not sleep tonight , thinking of different solution to do it wihtout some metal... But I think I must use some kind of strap to hold it , and it is a little metalpice on the strap but some rubber over it so is that problem solved....
But I am in the schoolbench this week so it take some weeks before My version is coming , but i like the ide´ with a traffic-cone ! And that model of cone is going out in Sweden other things is coming , all this thing from EU !
this user is offline now  Kris Leers 11-24-2008 00:27:43 reply | profile | send pm
Member
Vasa,
I will make a rubber piece on the hose where the cone clips over to keep the force going down, to prevent the clip to open horizontally I will fix a strap without metall.
What do you think.
this user is offline now  Vasa 11-25-2008 12:08:14 reply | profile | send pm
Member
It looks loke a good ide´ !
Hill-billy rough neck version 2.0
this user is offline now  Kris Leers 12-04-2008 14:21:03 reply | profile | send pm
Member
Do it like the pro's, no metall on your discharge hose.
this user is offline now  Kris Leers 12-04-2008 14:23:27 reply | profile | send pm
Member
this user is offline now  TooTall 12-04-2008 14:38:43 reply | profile | send pm
Member
There you go baby! Hey look, hose-man with no remote box! ha,ha. After your last post (the one with all the big red writing) I thought you might have been angry. Its OK I get very angry also! I have shot (2) computer monitors since I joined! HA,HA,HAA
Glad to see you're improving your device. You can call it the "Flow-Cone"?  Pump-On Kris!!!
this user is offline now  Kris Leers 12-04-2008 16:23:11 reply | profile | send pm
Member
Hi Too Tall,
wasn't angry. Just wanted to make some contrast to all the reactions.
I can understand them but I regret that on on the safety issue most of the replies just say your crazy and it's unsafe.
That I'm crazy, I knew that for a long time so I didn't need this site to find that out.
But on my arguments why I'm doing this and in which way it can contribute to safety if done in the right circumstances and with the necessary concentration, I get little or no detailed response.
Anyway, I agree that it's safer to have a good hose man on the hose and a good operator concentrating on the pump. The problem is that we don't always have a good hose man on the job site...
this user is offline now  Kris Leers 12-04-2008 22:21:15 reply | profile | send pm
Member
I've tried to put a video on video.concretepumping.com and I follow the steps to upload it but it doesn't appear. Don't know what I'm doing wrong.
Anyway, here's the url for youtube: http://nl.youtube.com/watch?v=QC-VYo7c3OQ
this user is offline now  Seed 12-04-2008 22:30:00 reply | profile | send pm
Member
I have to say I think you may be on to something! It looks like a 5" tip hose. so a 4" tip hose may bee a significant improvement to your device! This is a great alternative to a double 90! How often do you use it, What do your customers think?
this user is offline now  Kris Leers 12-05-2008 01:19:45 reply | profile | send pm
Member
Customers think it's great. I use it all the time.
It is indeed a 5" hose. Before we always used a 4" but you often get plugs in the reducer, especially since a lot of plants started with recycled concrete. They crush old concrete and use it in the production. If a long small piece of concrete passes the grid it will probably make it to the reducer and then block up the line. If the pressure raises and the plug releases you've got the equivalent of a canon ball coming out of the hose. Many accidents happened because of this among which a collegue of mine loosing his life 5 years ago.
To find a safer solution I started working with the 5" hose. The problem is the splatter when pumping at low speed. Therefore I came up with the cone. It gives a continuous flow and no splatter even if you pump at low speed. If there is a bigger stone, the cone will open and the stone will pass.
this user is offline now  Seed 12-05-2008 03:57:10 reply | profile | send pm
Member
Did you cut the end of the cone off and then put slits in the sides?
this user is offline now  Kris Leers 12-05-2008 04:34:53 reply | profile | send pm
Member
Yes, I did.
this user is offline now  PourItOut 12-05-2008 12:00:05 reply | profile | send pm
Member
Great idea Kris!!!! what keeps the cone on the hose?
this user is offline now  Seed 12-05-2008 14:20:16 reply | profile | send pm
Member
My thoughts exactly! I went out today with my cone fixed it all up like you said. I attached it with tie wire and gorilla tape. Primed out. It looked awesome. Flowed out smooth like a 3". Unfortunately when I  started pumping the wall it fell off into the wall? No one cared I hope it is not sticking out the side when they pull the panels. Lucky for me it is back filled in and out.
this user is offline now  Bob 12-05-2008 14:33:26 reply | profile | send pm | delete
Member
We need to know the secret of keeping it on the end of the hose.... with no heavy metal. ;~)
this user is offline now  Kris Leers 12-05-2008 20:24:50 reply | profile | send pm
Member
The problem is of course how to prevent the downward force pushing off the cone with no metall connection. After the first post on this topic you pointed out not to use metall for safety reasons and that was also my concern so I started searching for alternatives.
For now I just use plastic straps, the ones electricians use to bundle cables. A few around the hose and three going down works fine to me. Make sure you make slits in the side of the cone: in case the pressure raises the cone opens instead of coming down. If you start pumping, don't pump to fast untill the first concrete has come out. And in case of a block up it's better for the cone to come down then having the hose flying around under maximum pressure in case the plug releases. If you try it out, I suggest not do it on a wall till you got the trick so in case the cone comes of you won't lose it.
I've got something with a velcro strap but it still needs some improvement. I'll post pictures as soon as possible.
this user is offline now  TooTall 12-05-2008 21:23:02 reply | profile | send pm
Member
Here's the beginning of an idea? It will require some field testing and may require (2) of these but its pretty simple and light. It would also eliminate having to cut a "groove" or alter the hose in any way. You will have to click on the image below to view full size....
this user is offline now  Dapper Dan 12-06-2008 01:49:17 reply | profile | send pm
Member
hi Tootall about the 1 reply
I know Kris for a long time and i have seen him angry not often,maybe a little bit disappointed;
instead the lovesickblues he got the concreteblues
you can't fix that with 1 bottle Jack Daniel's
Kris just set your ampli On 10  and pull these string's
Keep on rocking
this user is offline now  TooTall 12-06-2008 16:18:35 reply | profile | send pm
Member
DapperDan Sir, There is a simple solution to any problem that is not fixed with (1)Whiskeybottle of Whiskey.........Get another bottle Whiskey Whiskey!!!
this user is offline now  Kris Leers 12-07-2008 12:11:42 reply | profile | send pm
Member
I've put another video using the cone on my website. You can see it on www.concretepumps.be on the page End hose reducer.
this user is offline now  Kris Leers 12-07-2008 13:00:47 reply | profile | send pm
Member
Here's a picture of how I put the cone on the hose at the moment: just a few plastic straps. It works fine but I'm working on something with a velcro strap to put it off and on more easy. I'll post the pictures as soon as possible.
Bob 02-06-2009
Sorry,
I must have hit the background by mistake.
Do not use twin 90s
Have your boss call me, I would be glad to talk to him.
Bob Sanderson - (770) 403-1444
pumperdolittle1 02-06-2009
A five to three inch reducing hose is what we use. Pretty much all the customers that use it love it and won't go back to the s tube.
kid 02-06-2009
I have never used a 5 to 3 reducing hose. But I have had problems with the 5 to 4 reducing hoses whiping when a clump goes through.
Bob 02-06-2009
kid
Don't feel like the lone ranger.
38zman 02-06-2009
Hey Kid....lol
I have come across your problem time and time again and I use a 5 to 4 reducer and then a 4 to 3 reducer with a 3 inch placing hose it works perfect every time just make sure you have safety cables on everything and I put a piece of snow fence over the grate that way nothing big will fall in the hopper and you will never plug. Just remember mixer drivers are not the sharpest knifes in the drawer and they may over load you because they dont get it....lol Makes me wonder some time how they tie up there boots... lol
 So how are you doing and did your mean and terrible boss give you the stickers I gave him to hand out to all of you....lol
Granite Pumping 02-06-2009
No 38zman he just stole the stickers...lol...lmao...lol
kid 02-06-2009
I am doing pretty good. Now I know where the stickers came from. Unfortunately I did not receive any of them. I saw them on some mixer drivers hard hats though lol. Must have ran out before he got to the operators.
pumpman3480 02-06-2009
i always use a ramshorn attached to the boom and then a single ended 3" whip
Bob 02-06-2009
Thats too bad. Why not leave that junk at the yard and just use the reducers and 3" hose? Your tip elbows 'brake' the concrete.
38zman 02-07-2009
MMMMM WELL I still have some left Todd sent me many and wait till you see the shirt your boss has on one day....lol I will give him more for you guys.....
ShortStik 02-07-2009
hey kid.  alway think of others but also think of yourself. i dont know if id be able to pump again if i saw someone take a double90 in the face from my boom after reading the chatter at this box.
do yourself, your custumer, your company and the industry a favor.   NO METAL on your discharge hose!!!  Just refuse.  It is your right.  Keep your head on your sholders, explain the dangers again and refuse.
