concrete animal | 01-19-2007 | comment profile send pm notify |
Hey gut's I've one pump cylinder that needs resealed (and rechromed) but want to put it off a couple weeks, fairlywell booked next coulpe of weeks. Is it possible to replace the seals (o-ring , backing ring seal gland and scraping ring) and pollish out the scratchs without removing the cylinder to try and buy a little time till Im not giving up to much time with truck down?? Schwing 1200 kit on a 1985.. Its Leaking hyd. fluid in to water box, Don't know exactly how much. Enough that water box over flows after about 200 yds. Thanks |
bisley57 | 01-19-2007 | reply profile send pm notify |
Easy to change on Schwing,take out bone,remove flange from rod,remove face from cylinder,inside water box,weld or braze 3 or 4 inch wood screw on screwdriver,turn screw tool into packing,yank it out,replace scraper and o-ring,replace packing ,re-install face,flange,and bone.....should take no more than 3-4 hrs.Turn rod in main cylinder weekly so seal does not get damaged too quickly.With a leak as bad as you describe,moisture has a better chance of entering the hyd. system,it might be a good idea to repair as soon as possible. |
concrete animal | 01-21-2007 | reply profile send pm notify |
thanks I'll check availability of a rebuilt monday, have to make a trip to schwing early in week to pick up new rough neck any way. Seemed to go thru around 5 gl. on 220 yards Saturday |
concrete animal | 01-22-2007 | reply profile send pm notify |
SPEEDY; SCHWING SAYS THEY ONLY SELL NEW CYLINDERS AT $6200+ .. DO YOU KNOW A SOURCE? THAT COST VERSES $2000 OR SO TO PULL MINE, MAY JUST REPACK AND HOPE TO GET A COUPLE WEEKS MORE. iVE GOT TWO PROJECTS WITH JUST TWO MORE POURS. THEN IT WONT HURT TO DOWN IT FOR 4 OR 5 DAYS. |
Seed | 12-13-1901 | reply profile send pm notify |
Concrete Animal, How did this all play out? |
