| b-alto | 07-28-2016 | comment profile send pm notify |
Did you know instead of using Acetylene gas for a cutting torch you can use propane? Yes its true. It works just as well and is much cheeper and readily available. The gauge actually screws right into the tank off your gas grill. It works better if you get a different tip for the torch. I saw a guy at the RM plant doing it. |
| gboom | 07-28-2016 | reply profile send pm notify |
Brian, The gauge connection for acetylene is a left handed thread, on your propane tank ii is right handed thread. Whatever you saw on that video is a homemade contraption, and please do not copy this, this is a safety issue. The reason acetylene is used, is beacuse can reach temps up to 5000 deg F, |
I guess you actually saw the guy doing this, this is even worse than the video i thought you saw it. |
Well , half of my post was cut off. You use acetylene becauuse with the temps you can cut and |
| b-alto | 07-28-2016 | reply profile send pm notify |
It was not on you tube, it was real life.. when was the last time you changed your propane tank? its left hand.. I will go and take a photo of the torch set up soon. Not tomorrow i have a 12 hour day of pumping. But thanks for your input. Thats why i post interesting stuff. |
| orygun | 07-29-2016 | reply profile send pm notify |
did you genus guys get your drivers licenses in a box of cracker jacks |
| pudg2 | 07-29-2016 | reply profile send pm notify |
outer thread on propane (new bottles) are right hand threads , the inner threads are left handed . An yes you can cut with propane . |
| SUPERDOFFER | 07-29-2016 | reply profile send pm notify |
If you know a litle bit about welding and cutting. You know you need acetylene for weldingand can use propane for cutting. in the cutting proces you need the gaz to reach the melting point and the oxigin to burn the steel. |
| b-alto | 07-29-2016 | reply profile send pm notify |
I can't get the photo to post. But yes it works for cutting. I usually weld with an arc welder. |
| biged | 08-03-2016 | reply profile send pm notify |
Brian propane doesn't get as hot as cutting gas no matter what always use blow back values if you ever get a gas hose on fire just turn off the Bottle never leave it burning,for heavy welding stick is best light duty get a Mig welder there are several gases you can use with a Mig. |
| b-alto | 08-04-2016 | reply profile send pm notify |
Thanks ED, good to hear from you. If a person ever looks at the torches at a scrap yard they often have a large gas tank and i believe it is usually propane because it works and is cheaper. A good quality torch set up and tip is key. (which i need to invest in..) |
| biged | 08-04-2016 | reply profile send pm notify |
Brian just be careful that's number one thing I know how it feels to get burnt. |
| crete | 08-06-2016 | reply profile send pm notify |
Hi Big Ed and Brian. I actually started welding as a hobby a couple of yrs. ago. I have made all my form baskets for my 9' forms. Also so handy being able to built small brackets ladder rack etc. On my own time schedule is great. So far I've acquired a 250 amp mig welder, torches,cheap press,carbide chop saw.. My latest investment was a 50 ton ironworker (makes quick work with shearing,punching bending notching). Once your set up to do your own stuff you won't believe how many projects you can dream up.Terry |
