MANNY | 10-03-2011 | comment profile send pm notify |
ok now that it is final that i will be getting into the pumping biz i am going to start small line pumps. now i am doing reasearch and there are so mamy pumps and im sure i will get tions of different brands that are the best, but if you have the time i would apreciate your input on a particular brand. i will be buying used. for instance i found this pump which i am reall thinking of buying but me and my partner said we are going to wait a month and look at every pump we can find that seems reasonanble as to not make impulse buy on the first pump we see.. here is the first pump i am going to go check out on wed. what are your thoughts if any. A 2002 OLIN 5/65 pump is had a new cummins diesel engine put in in 2006 comes with 150ft of hose reducers for $11,000 i may be missing something but if you guys have any input on what i should be checking for on a used pump i would aapreciate it thanks
79xlch | 10-04-2011 | reply profile send pm notify |
The Olin pumps are very good. Very inexpensive to run and easy to replace wear parts compared to other pumps. No grease fittings to worry about either. Being a ball valve pump they do like a good mix though and you are limited to small rock. Who wants to drag a 3 or 4" hose around though for pumping big rock. I use 100% 2.5" hose with my Olin. |
Dipstick | 10-04-2011 | reply profile send pm notify |
Just a funny thought but don't let them trick you when they say 150'' hose and then they keep the clambs themselves.. |
PumpKid_88 | 10-04-2011 | reply profile send pm notify |
olins are the best pump i ran good running pump but any pump u git will be good as long u take care of it im a putz guy so i wont say to good about to much but u wanna run 2in the olin,mayco,putz a30 will be the way to go big line putz 50,70 good pumps even the 1100 are good but its all ur likein buddy if it was me id go with used pumps for right now cuz the market aint all that gr8 so no over hang with paments needed to worry about but good luck buddy if ya need a opr give me a email i pack vary small |
Drew AUS | 10-05-2011 | reply profile send pm notify |
An old 1408 putz might be the go..... look at it as an option I think you would be a lot more versitile and if the work is a bit slow it might be that edge you have to keep you going. |
wannadrag | 10-06-2011 | reply profile send pm notify |
MANNY PM me. |
