Matthew | 04-13-2011 | comment profile send pm notify |
Got a question for all you mack boys out there. I'm running a schwing 32m on a '98 mack chassis with the E7 powertrain. Problem is I'm going through belts way to fast. damn belts are always squeling. I've checked and rechecked the water pump, the pulleys, used a framing square to make sure they all line up, everything. Can't figure it out. Anyone else out there have the same problem, or is it just me. Starting to think it's just a damn design flaw. The squeling's getting damn old though, I can tell you that!! |
Tank | 04-13-2011 | reply profile send pm notify |
Get a 2005 or newer and you won't hear the squealing belt |
PumPro | 04-13-2011 | reply profile send pm notify |
Sounds like you need a new tensioner |
mtnpumper | 04-13-2011 | reply profile send pm notify |
Had the same problem... started switching brands... Gates i believe stopped the problem.. Carry a spare! |
cretepumper2 | 04-15-2011 | reply profile send pm notify |
Check the tensioner pulley. We had a truck that was wearing belts out fast too and that's what we had to do. Ours was a 2007 I believe. After we changed the tensioner pulley the problem went away. |
pumper chuck | 04-15-2011 | reply profile send pm notify |
Your right Tank,he wont be able to hear squeeling belts on 2005 or newer. the damn fan will silent everything
Gates belts should quiet the squeeeeell . |
