| EPDAS18 | 11-12-2024 | comment profile send pm notify |
Concrete Batching Plant Without Foundation can ensure the smooth production of ready-mixed concrete at the construction site, and the foundationless design saves manpower and material costs. However, it requires continuous maintenance to ensure optimal performance, safety and service life.
Daily Cleaning and Inspection
After each day’s operation, clean the inside and outside of the drum wall, discharging mouth, stirring shaft, and residue on the discharging door. Water can be used to wash these areas, and if necessary, a small amount of stone and water can be mixed for a more thorough clean.
TipClean all equipment regularly, especially mixers, conveyors, and aggregate bins, to prevent the buildup of concrete residue. Ensure that moving parts, such as the drum and conveyor belts, are properly lubricated according to the manufacturer’s guidelines.
Calibration and Testing
Conduct daily inspections of all components, including silos, mixers, conveyors, and control systems. Look for signs of wear and tear, leaks, or any unusual noises that could indicate potential failures.
TipPerform more thorough inspections monthly. Check the structural integrity of the Mobile Concrete Batching Plant, looking for any signs of shifting or settling. Establish a maintenance log to track all inspections, repairs, and part replacements.
Check for Wear and Tear on Key Components
No Foundation Concrete Batching Plant relys on several critical components, such as the mixer, silo, weighing system, and conveyor belts, which can wear down over time due to continuous operation.
TipConduct routine inspections of high-wear areas, including the mixer blades, bearings, and hoses. Replace worn-out parts as soon as possible to prevent further damage.
Checking Weighing Systems
Weighing systems are crucial for accurate concrete production. Regularly check the weighing hopper for interference and ensure it is in a free state.
TipPerform regular calibration of the weighing scales to maintain accuracy in the mixing process. Test the calibration after any maintenance or when the plant is moved to a new site, as environmental factors can sometimes affect scale performance.
Inspect and Clean the Air and Water Supply Systems
Foundation Free Concrete Batching Plant use air and water systems for cleaning, dust control, and lubrication. If these systems become clogged or malfunction, it can lead to reduced efficiency or equipment failure.
TipCheck the air and water filters for debris and replace them as needed. Inspect the pipes and hoses for leaks or blockages, and clean them regularly to ensure proper function.
The Foundation-free Concrete Mixing Plant has a unique design and does not require complex foundation construction, which greatly shortens the construction period. It has a compact structure and a simple and quick installation process. This rapid deployment capability enables the foundation-free concrete mixing plant to be put into production quickly to meet urgent or short-term concrete production needs. https://www.epmachine.com/maintenance-tips-for-concrete-batching-plant-without-foundation/ https://www.epmachine.com/ |
