Need help bad, adjusting hydraulics on my pump
barron 11-18-2011
I need someone to come over and adjust the operating pressures of my pump, I'm just not getting it, after installing new main pump a few months ago, i can't figure it out, the limiter kicks on all the time, making pumping impossible, I keep playing with it in the field but I don't get it, yeah I have the manual, but I'm a watch and learn guy, last straw was last night, 200' feet of line for a wall pour in the dark, 5 slump, pea gravel mix.... Easy. Stopped pumping after prime, the limiting thing hanging off the main hydro pump, kicks on, I had to bring in my trusty sidewinder pump, hooked up to my line already out with concrete sitting in it for 40 minutes,.... No problem. I will gladly pay, please help, I'll drive to you if need be
murf 11-18-2011
what make and model?
barron 11-18-2011
Oh yeah, it's a whiteman/conspray sv50
Boom Inspector 11-18-2011
Hey Barron,sorry you are having so many issues. Im not sure where you are located at ? But Give Joe C a call 812-987-8356,he has his own business as a service tech and can most likely fix your problem and can drive to your location. Hopefully this will help ?
Good luck
Todd 11-18-2011
Barron where do you live?
barron 11-18-2011
I'm out in carnation washington,
predater 11-19-2011
give me a call 360-608-1117
