Need help finding Hyd pump
SMOKIN JOE 01-14-2015
Hi, I have a 1985, 32Meter Putz, It has a 12 cell pump, Parts book says it's a A4V 125 HD. I gave my local putz dealer my part book number and they say it's no longer available. The splines on the pump shaft stripped along w/the coupler, I t may be possable to rebuild it w/a new shaft if rex roth still has them. I have not had luck in past years w/Rebuilt hyd. pumps. Were can I find a new one ?, The Info tag that was on the pump is gone so the only rex roth number I have is A4V 125 HD. Help !!! Thanks. Joe S.
Beast 01-14-2015
call north american 225 927-4972
lucky phil 01-15-2015
you can just replace the input shaft providing the pump internals are ok. Will be a lot cheaper as a new a4vg125 is around $12500
PUMBO 01-15-2015
You will more than likely find such a pump commonly available in Greece and Turkey much cheaper than you would think now that the $USD is so strong. If your willing to go that route shoot me a PM and i'll pass you the contact.
biged 01-15-2015
Hey I had a 1989 Puzt that done the same thing I found them at a company in Indiana close to Indy had them fast get booth side's of the coupler, I will look later for the company name.
SMOKIN JOE 01-16-2015
Thanks for the reply's, And yes any and all info you could pass along would be great. I would rather buy a new Hyd pump versus a rebuild. A new Hyd. pump in there should outlast me pumping.  If I put a new pump and all other couplers and new top shaft it would be equel to 3 or 4 payments on another Pump truck. The Concrete suppliers and other wall guys pump to cheap for me  to be to able get something new'er and still not stress out trying to compete against them. Again Thank You. Joe S.
BEAST, Will north American have a new Hyd. pump ?, Who are they?, Hyd shop?,Pump parts company?
