boater | 12-31-2008 | comment profile send pm notify |
Hello to all ,I hope you all had a great Christmas and are planning a safe New years eve....sorry I got side tracked I am new to pumping ..this will be my 2nd winter but the concrete Co. I work for is very slow ...average 2 pumps jobs a week. And my training was minemal can anyone give me some advice on winter pumping? I do make sure ALL water in drained at night and I do park it in a (unheated) garage,but I have still had trouble twice with some freezing in the water pump,hose and lines while in transport to job sites.I should ad it is a 2006 Schwing 32 meter. Any and all help is appreciated. |
pudg | 12-31-2008 | reply profile send pm notify |
your water pump and hoses should be drained until ready to use they should have drain valves for this and a little anti freeze in your water tank probably wouldnt hurt either |
Mudslinger | 12-31-2008 | reply profile send pm notify |
Welcome: I use an airhose adapter I made to blow out my waterhoses.Just empty the tank and open the draincock below the water pump,and blow it out GENTLY. Works for me.Clears out the hose and the pump. |
Bob | 12-31-2008 | reply profile send pm notify |
Mudslinger, I am with you. That is the only way that you can be sure. |
typesdubs | 12-31-2008 | reply profile send pm notify |
Likewise, but I also put some used antifreeze in the line before I hook it up to the air tank. Make sure you don't blow up the plastic tank! Seen more than a few people do it by not opening valves or draining the tank first. |
bri | 12-31-2008 | reply profile send pm notify |
I used to hook up air to my water nozzle and blow everything out twice to make sure that there is nothing in the pump or the lines. |
TooTall | 12-31-2008 | reply profile send pm notify |
You can insulate your water pump with lots of stuff. Keep your water hose and nozzle in the cab while in transit. Keep a small propane torch in your pump for emergencies. Also a small bucket of calcium cloride pellets with a lid. When you put the calcium pellets in water, the water gets scalding HOT and will defrost most any thing. But be careful, too much will boil right through a plastic bucket. In my pump as we speak is an old, goodwill electric blanket that has saved my frozen ass several times!!! |
