KAL | 10-10-2008 | comment profile send pm notify |
http://s257.photobucket.com/albums/hh201/kalvin1000/?action=view¤t=3b164ebe.flv Above link a video of the line, this pump is only running at half speed, concrete is being pushed about 4 meters from hose end http://i257.photobucket.com/albums/hh201/kalvin1000/081008pump315.jpg The pump showing a small crane and other attachments. |
b-alto | 10-10-2008 | reply profile send pm notify |
Those handles are nice, I made one for mine a month ago. Sure saves the back. Only problem I've had is the kinking, wears the hose. |
KAL | 10-10-2008 | reply profile send pm notify |
You are right the T-bar with a solid ring does allow for easy handling of the hose, however I have not had a problem of wear at that point, 1 I only use steel braided hose 2 I use the bar to lift the hose, using the pumps pressure, and I do not kick or pinch it at that point. 3 I always replace my hose as soon as I find a soft point, even if the hose is still "good" for a few more cubs / yards. |
Mr wibau | 10-10-2008 | reply profile send pm notify |
hi kal, what sort off line pump is that and are you using the surge pipe. |
i mean what size pump is that |
A TRANSCRETE P90 HP with an 88inch stroke. |
Don't need a surge chamber with this pump, you can contact transcrete to get further specs of the systems internals. |
