| HCB concrete | 08-22-2024 | comment profile send pm notify |
Pump is a 2006 Reed. One problem is when pump is engaged after warms up it will pump one cylinder fast and other will pump real slow, taking 5 time as long or more to complete stroke on that side.doesnt do it 100% of the time. I’m assuming this is in control block not hydr pumps tandem 125’s. It’s at a hydraulic shop now. Any input welcome. |
| orygun | 08-22-2024 | reply profile send pm notify |
a competitor got excited to buy a used T-A nice pump but has the exact same quirk in the stroking. guess its been through three shops without a proper dianostic. my wild guess could be a blockage in the control block, but iam really interested in the outcome. |
| Todd | 03-31-2025 | reply profile send pm notify |
Reed Concrete Pump Cycling Issue AnalysisThis uneven cycling issue on your 2006 Reed pump is something I've seen discussed by experienced operators. Your assessment that it's likely in the control block rather than the hydraulic pumps is probably correct, especially since:
Likely CausesControl Block Issues
Less Likely But Possible
RecommendationsSince your pump is already at a hydraulic shop, make sure they specifically:
This issue is relatively common on concrete pumps with some age, and usually fixable once the specific component in the control block is identified. |
