Odometer sensor of Sany concrete pump
Prime concrete pumping solutions 05-15-2019
Hello ,
Any idea where is odometer sensor is  located in a 37meter Sany concrete pump based on a Isuzu chassis
poohbear 05-19-2019
the sensor for rpm is located om the cab side of the pto box. It needs a 4mm gap or less between the sensor and the signaling plate tabs. Sometimes the plate halves break off. Another suggestion is there's a plug up about 16 inches up from the sensor and sometimes unplugging it and plugging I back in can make a better connection. Contact putz parts for replacement sensors and signaling plates if your are bad. They should have them in stock
