PEAGRAVEL PRO | 07-04-2011 | comment profile send pm notify |
Does any body know of anyone in the southern ca area tht has an olin rock pump for sale besides the one in the used pump section. I would mainly be using it for shotcrete .also i have a 2006 olin 565 for sell with 1800 hours on it |
79xlch | 07-05-2011 | reply profile send pm notify |
How much for the 565
biged | 07-05-2011 | reply profile send pm notify |
Whats wrong with using the 565 for shotcrete, 79 don't you use you 5/45 for shotcrete sometimes. |
PEAGRAVEL PRO | 07-06-2011 | reply profile send pm notify |
nothings wrong with using it on shotcrete jobs its just more convienyent with a rock pump.ive been doin about 2 to 3 shtcrt jobs a week and when it gets later in the day and the guys want it at a 2 to 2 1/2 in slump its a pain in the ass with a ball valve pump,swing tube or rock valve leaves me a little more room for comfort |
ive been seeing them go for 26,000 but for mine with a new paint job and new hopper im lettn it go for 21,500 |
biged | 07-06-2011 | reply profile send pm notify |
Yes you are right it doesn't like that 2 1/2 in slump, if you had a pencil vibrator you could put it over the balls in it would drop in. |
i have a vibrator mounted on the front of the hopper right above the surge chamber and ive found that for one rm drivers are stupid and dont know how to turn it off when they fill my hopper a little to full (even though i pointit out to them several times). or if i sit for a long period of time and it doesnt get shut off it packs the balls in pretty tight. i just think the easiest solution is getting a rock pump again |
79xlch | 07-06-2011 | reply profile send pm notify |
Yep. once in a while balls are ok. Full time shooting needs a wide open hole. Better yet a Reed dry process gun, that is the best thing since can beer. |
I got two vibrators one behind the surge chamber and one on the bottom side of the screen what I was talking about was a hand held vibrator to move from one ball to the next , for stiff grout you really need a screen vibrator, I see you drift a s-tube pump will pump stiffer grout. |
i bet with that one on the screen it makes that mudd fall through the screen great, but what a pain and the ass to take tht screen off? |
I don't take my screen off, I have a little short chain with a hook to hold it up to spray out my hopper then to clean the dried concrete I use a air chisel to get it clean, I started using DC -60's 12 volt from Vibco they cost about 300.00 each, I never pump without a screen stiff grout can be slow getting it threw even with my vibrator's. I have very good mix's in my area the company that don't I refuse to pump them or even try. |
where are you out of? im in the riverside county area and its hit and miss with good mixes out here.wht kind of olin do you run/
biged | 07-07-2011 | reply profile send pm notify |
I live in Clarksville Tennessee, I run a 2007 5/45 OLIN they are the best ball valve pumps you can buy easy to work on parts are cheaper than s-tube's I have almost 1100 hours on this one. |
PEAGRAVEL PRO | 07-08-2011 | reply profile send pm notify |
yeah olins arebyfar the best ball valve peagravel pumps around.most universal too. |
