mtnpumper | 12-09-2009 | comment profile send pm notify |
On a sixty M or bigger {Juggernaught} Do you pull a ball back, Where does all the mud go, and the prime do you use pacs or cement? Water? Port? Just wondering. |
pudg | 12-09-2009 | reply profile send pm notify |
I have ran a 58m and didnt do anything different than I did on a smaller pump, did at times overflow out the hopper when sucking a ball back but that happens sometimes on a smaller pump also, and as far as priming I used slick pak just the same , never had many problems grout is always better but good luck getting the customer to pay , and the sacks of cement is just to much of a hassle |
zuat150 | 12-09-2009 | reply profile send pm notify |
I always pump the hopper down turn it to 10 give it 2 more strokes A framed and put the ball in and have never had more than a hopper up to a 61 because the last sections get drained by gravity. |
typesdubs | 12-09-2009 | reply profile send pm notify |
Slick pack on the 58M I run. Full throttle, strokes at max, has never let me down. The hopper has a lid so we put the boom away from anything/anyone and pump it down, then suck a ball back. No spill. |
NCPumper | 12-09-2009 | reply profile send pm notify |
I ALWAYS PUMP MY HOPPER DOWN TILL I GET AIR OUT OF THE TIP HOSE, SUCK BACK AND NEVER HAVE MORE THAN HALF A HOPPER, AND THAT IS UP TO A 47. NOW IF YOUR HAVING TROUBLE SUCKING BACK BECAUSE YOUR SUCKING AIR IN THE HOPPER, JUST PUT ENOUGH WATER TO COVER YOUR MATERIAL CYLINDERS. |
Pump N00b | 12-09-2009 | reply profile send pm notify |
In my experience you get as half as much mud in your hopper after you suck the ball back if you pump it out with the boom in Z than in A. |
YEA, THIS IS TRUE. BUT MAN TO TELL YOU THE TRUTH, I CAN'T EVER GET MY SPONGE TO COME BACK IN Z, UNLESS I FOLD UP AND PUT THE BOOM IN THE CRADLE. |
Yeah, it can be a bitch to get the ball back in Z if you got sticky mud, loose cutting ring, bad gaskets... whatever or just a bad day. |
baddogpumping | 12-09-2009 | reply profile send pm notify |
waterwash when ever I can
yard whore | 12-09-2009 | reply profile send pm notify |
WATER WASHIN THE 61M ALL THE TIME AND JUST WATER ON THE PRIME. |
