| Concrete7111 | 04-23-2013 | comment profile send pm notify |
How much power should my outriggers on a 28m Putz have? Inorder to lift the wheels I have to realt work at it side to side. Is there a pressure adjustment or is the pump getting weak? |
| Travelteck | 04-23-2013 | reply profile send pm notify |
E Mail me your Serial Number, I can check it out and let you know. There are 2 settings at the hand valves on each side. One for chain and Slewing and One for foot Jacking Is your boom running OK ? |
| Concrete7111 | 04-23-2013 | reply profile send pm notify |
Yes the boom seems to be functioning fine . But the outriggers seem weak. I can get it to lift the tires off the ground but it's gotta be revved right up and i have to work it from side to side one inch at a time. I'll email you the serial number later. |
| billdoe | 04-23-2013 | reply profile send pm notify |
iv got a new 40z thats the sameway |
I just seem to recall it being much stronger. I could be wrong though. |
| The Punisher | 04-23-2013 | reply profile send pm notify |
Regulator at the hand valve maybe. Or holding valve sticking. |
| Mister_Perkins | 04-24-2013 | reply profile send pm notify |
Is this happening with the boom folded up, or unfolded, or it doesn't matter ? |
| Concrete7111 | 04-24-2013 | reply profile send pm notify |
I've only tried with the boom folded up. Today we played with the pressure relief valves on the hand valves on each side and it seems much better. I turned the relief screw in about 2 turns and it made a substantial difference |
