Perkins/REED Line Pump - Starter went out
pumpSHEP 06-18-2012
Two starters in 120 hrs on a Reed AHP30. Anyone have the same trouble?
PumPro 06-18-2012
Check and clean your battery connection If it is not good it can burn the starter out
wannadrag 06-18-2012
Or a failing battery/slow cranking will kill starters.
Travelteck 06-18-2012
Do you use Acid to clean your pump?
Acid will attack the copper in the motor windings and cables.
I have seen pumps that have been washed with Acid that have major electrical issues the vapors get into everything.
Food for thought
pumpSHEP 06-19-2012
Never acid on my pump, battery is very clean. I spoke with a reed dealer, he said sometimes the vibration makes the key stick, stupid but hey it is what it is. Im going to add a push button start.
Thanks
b-alto 06-19-2012
Here in Bemidji MN there is a repair shop called Terry's auto electric. They rebuilt all starters for usually under 70 dollars. They could save you money and also tell you what the cause is. I had my skid steer starter rebuilt last week for 65 bucks.
Goose2448 06-19-2012
Huh, my A40HP has a push button start.  And like I said, it seems to be a common thing with that Perkins
