pinch valve rock jams??
sgt580 05-14-2008
Any suggestions???? The pnuematic pinch valve on my schwing 39m gives me rock jams in the reducer if I stop pumping for more than a couple minutes. I know its caused by the cream leaking past the bladder. When inflated it leaves a 3/4 inch opening. I was just wondering if anyone else has this prob or knows of a fix. Right now I just run a little bit every couple of minutes thru the break to drop the rocks out before it plugs.
greedy 05-15-2008
 i have the same trouble here in england where our concrete supply is very poor if i leave the rubber squeezed up for to long the concrete bleeds causing a blockedge i turn on pump without reves so bag opens let some concrete fall then turn of pump to squeeze again that all i can say my squeeze valve is a putzmeister valve that fits over the rubber
Sidetracking 05-17-2008
what type valve are you using, how much air pressure, is it automatic or manual, steel or fabric 4" or 3" tip hose
Sidetracking 05-18-2008
Are you reading your replies....? If so please respond. I can help.
