pipe end size
murf 08-02-2009
been looking at the mud snake, but it comes with a "california hd end" - can anybody let us know the dimensions/picture of this ?
zuat150 08-02-2009
I believe its 4" if thats what your asking
murf 08-02-2009
we use a standard 127mm collar over here so will have to make up an adaptor- was just wondering what the collar on the ms pipe was
eugene 08-02-2009
can you get a 5 X 3 reducer and put your 4.6 weld on adapter on the top and cut the bottom at 3 7/8 inch and just weld it on the mud snake
Secret Squirrell 08-02-2009
Murf let me ask a simple question do you use a 'conform' 5 to 4 reducer with a metric 5" to a HD 4" if you do then look at the 4" end its the same. Then look at the end of your hose ware you clamp it on to the reducer it to is the same except the way the clamp is swedged on to the MS.
murf 08-03-2009
s s - so what you are sayin is a california hd 4" is the same as the metric 5 only in 4? I thought that because it was hd (heavy duty?)it might be more like the schwing end with male /female?
murf 08-04-2009
zuat, eugene, and squirrel  - thanks guys
