| piggy | 08-09-2009 | comment profile send pm notify |
I've operated a 37m Sermac for the past 2 years, and have just started putting the 3rd set of pipes onto it. Is this wear normal for this type of pump? |
| pumperman | 08-09-2009 | reply profile send pm notify |
depends on type of pipe yardage pumped agg that is used and if u r maintaining the pipe by turning and flippin when it needs to be |
| nzpump | 08-09-2009 | reply profile send pm notify |
Piggy, from what I understand you have done 40,000 cu metres or 52,0000 cu yards with two sets of standard ST52 pipes. |
| Many | 08-09-2009 | reply profile send pm notify |
mmmm I guess I was never an advocate of piping only one section,promotes uneven wear.In the older days I pretty much had the wear areas figured out,not so today.Now on the flip side you still have pipe from the prievious piping you could use that to balance out the boom. If not just pipe the boom and save the old for replacemt later.The old elbows work great as tip catchers to burn them up.A passing thought would be contact the folks at conforms (sponsor) and poise this question to them,or your current supplier. Good Luck |
I never got out of the habbit of flipping/rotating pipe either.Your agg type,pipe type,pumping volume all enter the equation. |
| Todd | 08-09-2009 | reply profile send pm notify |
http://www.concretepumping.com/dictionary/index.php/Stop_Pushing_the_Big_Money_Button_on_your_pumps |
| murf | 08-09-2009 | reply profile send pm notify |
piggy- sounds about right if you are running the basic st line that comes with the pump- try up grading to twin wall. |
| pumper chuck | 08-10-2009 | reply profile send pm notify |
piggy' just checked out your profile. where are they takeing your pump ? no mud up there..ha. with murf on the pipe.. |
| piggy | 08-10-2009 | reply profile send pm notify |
it was coming down from the top floor.we wood put the boom down the lift shaft three floor and pump it.the crane lift 2m skips up to the pump and we wood do 60m at a time.We started at the 11th floor work our way up to the 21st floor
| igo | 08-14-2009 | reply profile send pm notify |
Ihave a little sonic thickness guage and I ckeck and rotate pipe and only replace as needed.Saves alot of money the cost of the guage was about a grand but it has paid for its self. |
| Pump N00b | 08-14-2009 | reply profile send pm notify |
Yeah, but those gauges only works on single wall st pipes. |
