| oldscho0led | 05-27-2013 | comment profile send pm notify |
Mates can you help me regarding this. I need to know how many Kaic (kiloampere interruptive capacity) is needed for circuit breakers for Putz MXR 28. Thanks. |
| Travelteck | 05-28-2013 | reply profile send pm notify |
Can you get me a serial Number for this unit. This is probably from Germany and it might be best to call them, you are using a diferent power voltage then us in the USA Dont want to send you the wrong way by guessing. With a serial number and your operating voltage I can look into it but it might take longer than if you contact Germany direct. Either way we will try to help, I am assuming you are looking for the Size breaker for the main load lines from power source. |
| fat controller | 05-29-2013 | reply profile send pm notify |
IN MY EXPERIENCE WITH TOWER BOOM POWER SUPPLY YOU NEED TO GET THE ELECTRICIAN TO INSTALL A D-CURVE BREAKER TO ALLOW MORE CURRENT TO BE DRAWN AT ELECTRIC MOTOR START UP . OTHERWISE WHEN YOU TURN THE POWER ON IT WILL INSTANTLY TRIP THE CIRCUT BREAKER. HOPE THIS HELPS ... NEVER PLAY WITH LIVE POWER SEEK PROFESSIONAL HELP |
| oldscho0led | 05-31-2013 | reply profile send pm notify |
I already know how many kaic needed but at what voltage? 400V also? |
| oldscho0led | 06-03-2013 | reply profile send pm notify |
How many amperes MXR 28 has, for the circuit breaker. |
| Grandad | 06-06-2013 | reply profile send pm notify |
600 volt 3 phase |
