Baldy | 05-09-2008 | comment profile send pm notify |
Been pumping for about 6 months now, and sometimes will always get plugged at the reducer, no matter how wet I pour or how stiff. Run a 36m how can I prevent this???? |
Dickie | 05-09-2008 | reply profile send pm notify |
are you talking about the 5 to 4 off the tip, or the reducing pipe on the back end? and are you rock packing when you plug? |
Bob | 05-09-2008 | reply profile send pm notify |
One other question to go with Dickie"s Is this on a prime? |
sgt580 | 05-09-2008 | reply profile send pm notify |
plugs happen. if they are occuring during the job thru a 4" ruducer they are prob due to the batch or mixer sluff off from the drum. The mixer co can cause alot of probs if they dont clean thier drums out regulary |
b-alto | 05-10-2008 | reply profile send pm notify |
Buy a rough neck 5-3" hose. Their not cheap, but I hardly ever plug, you can see the hose bending, stop the pump and bang it out.Of course relieve the pressure first. Other wise use a 4" tip hose. |
ruck | 05-10-2008 | reply profile send pm notify |
It's the garbage concrete we pump up here.Just keep tring, But watch gauge,So you don't blow a line and kill someone.You have a short reducer right.Sometimes a longer one will help.Give me a call. Ruck |
Get the chain fixed? |
Baldy | 05-11-2008 | reply profile send pm notify |
Yes Dickie a 5 to 4 and not always rock packed. Seems like the mixes out here have alot of gravel The times I've had trouble the mix sucks and no not the prime have been doing alot of boom and pipe work recently prime goes through just fine in the boom and through the pipe it hits the hoses and will plugg there Thanks for all the help Jeff |
