| low card | 05-15-2007 | comment profile send pm notify |
I'm looking into a truck with air brakes so that I can pressurize a 200 gallon water tank, someone mentioned downsizing my truck and going with a water pump, is anyone familiar with this system? I'm pulling a TK-50 putz. |
| Bob | 05-15-2007 | reply profile send pm notify |
The last company I worked for had line pumps set up both ways. Air will give you lower water pressure than a hydraulic powered water pump, about 1/2. Now if your concrete pump is down [engine won't run] you will be happy with the lower/air over water system. When the hyd/water system is good to go it is the champion by far. I am not at all familiar with Ed's electric water pump set-up. Perhaps it is better yet???? For operator satisfaction the winner was the hyd/air set-up. 250psi water made clean out a snap and made short work of safely cleaning out 2 & 2 1/2 inch system |
| brandon | 05-15-2007 | reply profile send pm notify |
I'VE RUN TRUCKS BOTH WAYS AIR AND HYD. BOTH CAN FAIL IN DIFFRENT WAYS, SO WHY NOT HAVE THE BEST PRESSURE (HYD.). |
| L & N | 05-15-2007 | reply profile send pm notify |
Look at getting a flat bed truck and put a 150 gal. plastic tank from Tractor Supply $200 get a 12 vdc pump $90, if you have a generator get a one inch line pump from Harbor Freight 120 vac $50. You can use either one to transfer water. We use 12 vdc and 120 vac on our trucks with a pressure washer. Keeps everything clean!!!!!!!!!! Clean pumps run better. |
if you are going to go with a plastic tank get a 300 or 400 gal. you cant have too much fun or have too much water |
| low card | 05-17-2007 | reply profile send pm notify |
Big Ed Thanx for the info, would you happen to have any pics of your set up? |
