problems with s-tube kicking over
Dickie 10-13-2007
on my putz 38z the s-tube kicks over nice and quite to the left cylinder but slams hard when it kicks right, about one or two seconds after it kicks right I get a vibration and a whine sound from behind the hopper. its just started doing this, anyone have any ideas. Im wondering if the cutting plate is too tight on the right side, but why all of a sudden and the vibration and whine I dont have a clue. Havent had any problems with it pumping. any help would be much appriciated. thanks guys
PUMBO 10-14-2007
If its fitted with an accumulator, which it proboably is check that its charging correctly on the guage settings should be at 190.
PUMBO 10-14-2007
It also does sound that the cutting ring may be on a little tight. It all depends on what sound its making when kicking right. If its a pulsating sound it might just be that too.
Any Pump 10-14-2007
does it make any difference if you faze it in`it might be a check valve leaking, also if you put too much grease in the cups at the end of the change over rams this restricts it from changing over properly just a thought.
hammah 10-14-2007
 sound like a problem i had but i dont think its you problem. you pump is equiped with twin shift cylinders right? my pump had the single and it did that when the treads on the shift ram started to unthread from the knuckle.
pudg 10-15-2007
HAVE HAD BIG BEARING ON DISCHARGE SIDE OF VALVE LOCK UP DUE TO GREASE WORMS.IF YOU HAVE NEVER CHANGED SOFT PARTS IN BEARING SOMETHING YOU MIGHT WANT TO LOOK AT.
