TL | 04-23-2019 | comment profile send pm notify |
Hi, |
TL | 04-24-2019 | reply profile send pm notify |
Today I switched out 2 new K238 relays in the main control box and 1 proximity sensor under the fan, but the same problem occur. The Main hydraulic pressure jumps on every 4th stroke. This is a constant pattern. Anyone with any idea please let me know. Thanks |
Grandad | 05-03-2019 | reply profile send pm notify |
When you put pump in forward with your switch over switch pressure out each side of the main rods It sounds like its losing makeup oil. On that 4th stroke does it really hit hard like the piston hitting the end cap of the cylinder |
TL | 05-03-2019 | reply profile send pm notify |
yes, on the 4th stroke the piston does sound like it hit harder. Do you have any idea? |
orygun | 05-03-2019 | reply profile send pm notify |
have a 2006 tk40, so far i have not had that kind of problem. did blow the cups and the slurry got into the odd of four check valves. before the shift over the hydraulics would pressure up. putz and a dealer got me figured out. |
TL | 06-13-2019 | reply profile send pm notify |
What did you do to fix the problem? Last year I had both my mud cups replaced. After 4 months, I noticed grey slurry in the water box. One mud cup was cracked. I took it back to the tech to replace it for free because they did a bad installation. I don't know when it started but I might have grey slurry in the system or check valves like yours. How did you fix this problem? |
