Pump Star
Chezpump 12-17-2012
Any one with stroke limiter knowladge on a Pump Star please contact me 4196186968
pumpkid 12-17-2012
What is your issue?
Chezpump 12-17-2012
stroke limited stuck wide open
pumpkid 12-17-2012
on remote or hard wire
pumpkid 12-17-2012
make sure you are in snale mode
Chezpump 12-17-2012
Both Snale mode on Remote box? for boom? it does not work manuely as well
pumpkid 12-17-2012
snale mode on remote will controle stroke
pumpkid 12-17-2012
Do you have a wire digram?     look at the conection in PWM box wire #3  and the relay R4   i have had to jump a ground  from *12 to A1 A2 R4
Chezpump 12-17-2012
Thank you checking it now
pumpkid 12-17-2012
let me know    I can send you my wire digram if you need
Chezpump 12-17-2012
Is there way to adjust manuly adjust at cyloind ?
Chezpump 12-17-2012
That would be great and thank you stevec@irvingequipment.net
