Pumping 2" hose
MVCP 07-17-2013
Hello everyone,
I have a job on apartment buildings and we have patios to pour. We are pumping through the building on upper levels because of no access to the rear of the building. I have never pumped with my boom through 2" hose. It is pea rock and 6 sack so good mix i hope, 100 ft of hose tops. Any tips or concerns. I would imagine pump slow ??? Thanks
Mister_Perkins 07-17-2013
I always drop the pump down a few gears when pumping through small line myself.
b-alto 07-17-2013
Be careful of air in the system. Any disconecting for a plug or moving the boom can lead to air in the system which means POW! when you start again. I dis like running hose off of a boom because when in "A" frame position or vertical the mud can roll back when idle and create air pockets.
that's why you need an air cuff to hold the boom full of concrete ;-)
sgt580 07-17-2013
I pump off my boom with 2" all the time, just ask for grout to prime and turn down your pump strokes!!
ShortStik 07-17-2013
i refuse to use 2" line from 9" barrels.  had a very near miss/incident.  to much pressure IMO.  2.5" is as small as i go.  been kicked off rezy jobs for not having 2" line.  a half inch may not seem like much but i notice a huge difference and have not had the same issues with it.  i go low rpm.
IMO 2" line is for 4" barrels
Dipstick 07-19-2013
In my opinion 2'' line is only for grout. 2,5'' is for peagravel and 3'' for 22mm rock.. 32mm rock I would use 4''.
Dipstick 07-19-2013
If 2,5'' is realy to heavy to handle for your customer get some real men to do the job.. Not 12 year old girls...
ShortStik 07-19-2013
im with you dipstick.  the only time i used 2.5 inch was for high flow mix for 1.5 inch wood subfloor topping.  slow pumping and long time jack hammering the hopper and S-tube.
