| TMAC | 08-22-2024 | comment profile send pm notify |
Hi all, I found myself here doing research to get the ball rolling on starting my own pumping company. The ball is rolling with reaching out the contacts and companies who I have built relationships with through my current job doing some front end research to gather more information to ensure there is a true demand for concrete pumping. By no means do I plan to jump in to a large boom pump right away, a trailer pump is going to be my entry in to the world of pumping. Through all of my research I have landed on a Schwing SP500 but am open to hear the pros and cons of any brand. My goal with this post is to hopefully gain some more insight on things to run toward or stay away from when it comes to pumps, and some other questions I just can’t seem to truly get and answer for on line. Is pumping 3/4” aggregate 5 slump with a trailer line pump doable? A company we have used prior only runs per gravel mix through his TK-40 With planning to buy a used pump, is it more beneficial to find one that will come with hoses and fittings? Or start fresh with hoses and fittings? Are 2.5” hoses the way to go if pumping 3/4” aggregate or bigger? Estimated Average monthly maintenance costs of a line pump trailer? What would be considered a high hour machine? Will a machine that does 45 yd/hr put me at a threshold of the size jobs I’d be able to pump concrete on? I appreciate you taking the time to read the laundry list above and thank you to all in advance for your insights! |
| Curtis lux | 08-22-2024 | reply profile send pm notify |
tk-40 is the same pump as the w.p 500 50 psi more pressure with the putz and five y.p.h. less. just tuning. closed loop hydraulics vs. open loop we have small. medium and large half inch rock and run 2.5 inch line. doing a 50/50 3/4 inch and 3/8 inch rock pumps nice with a bad mix design your pump will tell you right away. pump standards are six sack mix. now i do pump a 5.35 sack mix if iam just blasting out a driveway have pipe turns off the pump or i do have a short three inch hose to get me to the ground. run goodyear / continental off the pump and softer korean / texcrete down the line. i do have a used tip hose but use all double coupled hose, as i connect back to truck. the hose size i buy is 16.75 or seventeens. most vendors do not know how to divide 50 by 3 all of my hoses are horse shoe. they will fit into a pickup and i can handle a hose off the truck with one hand and a clamp in the other hand. dumping one is half the work of trying with a 25 foot hose. |
