| orygun | 06-15-2025 | comment profile send pm notify |
ask putz what the procedure is on memory function. they say read manual. well the machine runs like its on eoc without it being used. so i run the rpm up hit the memory, then pump on. putz says pump on then memory. so pump off and back on it will return to rpm, but once or twice then back to what the pump wants to do. rev up, then down to sense operation, then to the happy operating spot. i want the rpm up so there is not the lag in pumping, while priming. and want to run for break in as to not have the engine lug. there is other items that i would like to bypass so it does what i want it to do. like having to plug a wiring harness for the radio that does nothing till the radio is on and cleared. |
| Todd | 06-16-2025 | reply profile send pm notify |
Here is my AI shot at the problem, let me know what you think. Putz is normally really good by the way. I understand your frustration with the memory function not working as expected on your Putzmeister pump. You're right that there seems to be a conflict between what you're experiencing and what Putzmeister support is telling you. Based on your description, it sounds like the EOC (Ergonic Output Control) system is interfering with your manual RPM settings, even when you're not actively using EOC mode. Here are some insights and potential solutions: Memory Function Issues:
Potential Solutions:
For Break-In Period:Since you want consistent higher RPMs for break-in without engine lugging:
Important: These modifications may void warranty or create safety issues. Document everything if you're still under warranty. Have you tried accessing the service menu to check if there are any EOC or memory function parameters you can adjust? |
