putz problem
gill 05-12-2009
i am running an 07 38 meter, and it has started an intermittent problem with radio remote.
sometimes when i hit any boom function that boom section moves and also the tip section goes out.
any suggestions
rick5z 05-12-2009
maybe a programming problem with your remote,  do you know how to reprogram it?
gill 05-12-2009
i know how to program boom speeds with a tele teach battery
bisley57 05-12-2009
Does it happen with the cable remote?
180 flyer 05-12-2009
Had the same problem with a 36 putz once. Remote and receiver had to go to Putzmeister for repair. You may be hardwired for awhile
ruck 05-12-2009
What remote do you have?
Theo 05-12-2009
mine was doing the same thing when I went left it would go up and left when I went right it went down and right only in rabbit mode.  I snail mode it would not go left or right.  I sent it to putz they changed the proportioning card.  Talk to mark at putz's radio repair.  If you have 2 units the same you could try changing the card yourself.
gill 05-12-2009
no i don't have the problem on hard wire
i think you are right tha its in the reciever, putz rep told me this evening that i would have to send in the remote and reciever to get it fixed. the only thing is it does'nt do it all the time and if it won't act up when they get it will they be able to fix it.
AK1 05-12-2009
same thing happened on my 03 32 meter remote problem send it in and run off the hard wire for awhile my hard wire worked fine wireless did just what your saying move a function and d section would move too
cp1 05-13-2009
Save some money and just send it to HBC directly.  And yes, I've sent in a ton of remotes with intermittent problems and they always figure it out if you give them a description of the problem.
Niklas 05-13-2009
I hade that same problem when I operated the boom in ebc mode....and we replaced the angle transmitter
gill 05-13-2009
thanks for the advice guys
pudg 05-14-2009
joystick problem call putz they will fix it it has happened on a couple of our trucks eventually its gonna shut the remote down.
gill 05-14-2009
i talked to the radio shop at putz , gonna send in remote and reciever while its still under warranty.
i passed by your yard last week pudg. u guys sure keep your trucks lookin good
Granddad 05-16-2009
Before you spend money on sending it away open the remote and check for moisture.  We tape silica bags inside to absorb moisture.  Those H.B.C. remotes can do some really interesting tricks with the tiniest amount of moisture.
Pump N00b 05-17-2009
Yep, there are alot of tiny microfuses on one of the lower PCBs that don't like moist. I used to keep mine in the cab and take it inside during weekends.
