putz remote keeps dropping out Tearing our hair out
Reco36 03-30-2014
hey guys k so we are at the point of tearing our hair out with this issue on our 07 putz z boom. the issue is when pumping or not pumping say washing out. the truck shuts the pump system down like someone has pushed a E stop or the battery has died on the remote. click the outrigger horn reset everything comes back on and we can start pumping again. And within a min or so it drops off again. rest and away we go again some days it will last the whole pumping job other days its like every five mins it drops off. we have tried changing batterys tried putting a extra wire ontop of the transmitter of the truck. talked to putz they said open up the remote and see how it all looks. so we did that and found a atenna wire off. so plugged it in and tried it out and works like a charm. k so now we have another issue push the volume switch on the remote and blah truck drops out. never did that before when you click the volume switch it never dropped out. So my question is why when we plugged the atenna wire in on the remote the volume switch acts up Yell any help idea would be great
cbconcretepumper 03-30-2014
You have a volume "switch"?? Not a dial?
Reco36 03-30-2014
yup push the switch up increase volume push down decrease volume. one notch at a time
Travelteck 03-30-2014
Ok you are not going to like this
have you. Tried the hardware remote ?
If this is working fine then something deeper is wrong in the remote, this test must be done
also design the truck is dropping out, do you mean the unit is going to e stop or just the RPM lowering , or the engine dies ?
Reco36 03-30-2014
we tried the black and white remote all works great on there volume and all. as for the truck dropping out it goes to a E stop function rpm lowers. boom and pump functions disabled
Have you tried a new battery or does it do the same thing with any battery you put In it?
Reco36 03-30-2014
it does the same thing on any battery we try I checked systems voltage at the brain and it shows thirteen volts with everything running
I know it's Sunday , do you want to chat about this ?
360 600 5695.  Cool
monday works also I am on west coast
Concrete7111 03-30-2014
I had a similar problem and solved it by cleaning the contacts on the batteries and on the remote with a small wire brush and electrical cleaner.
Davy41 03-30-2014
I had the same issue with the pump I run turned out the e-stop was bad changed it alls good now,(the one on the remote)
I'm no expert but that'd be my guess of order
1. Battery
2. Battery connectors( because that's common )
3. Your remote e-stop
again just a guess
Michael C 03-30-2014
There are pins that wear out where the battery makes contact. Sometimes the battery moves just a touch and functions drop out. This is an internal fix that needs to be done by the a qualified person. Try this, put a small "shim" of paper to wedge the battery in tighter. See if this stops the issue. If it slows it down or stops it, you have to send in the remote for service.
Reco36 03-30-2014
well ill try some of these suggestions. before we send it off. have been in contact with putz on the west coast in vancouver. here is just another question when you push the e stop on the remote the red light on the transmitter comes on saying no reception. but I will clean up the contacts and try shimming up the battery
mudcup 03-30-2014
I used to use a penny as a shim on an older pump I used to run
gboom 03-31-2014
check all your electrical connections, not only the battery connectors
pumpkid 03-31-2014
Had the same thing on are 2000 32Z     it would come and go   found out that it was the ground on the inside of the rear pannel that in on the male conector to the cable to the remote reciver.   If it all works fine on hard wire then look just at your remote cable     I have seen where the water tank has pinched the cable   clean all the conections and make sure they are tight      We had 3 bad electrical problems ALL was the groung wires
Beast 03-31-2014
same issues on a 42m putz ground wire in electrical panel on water tank, inverter box if its a 24 volt
Reco36 04-01-2014
I got the year of the pump wrong its a 05 with no dig display. correct me if im wrong but when you turn the remote on it beeps right same when installing a batt it beeps. so if it was a loose battery and the remote was powering down all the time woildnt it beep
pumpkid 04-02-2014
no it dont beep when the batt gets bumped   we have to keep a folded paper behind it to keep it tight   some times my fat gut hits it when i walk Wink
Travelteck 04-02-2014
Would sure like to talk with you about this unit.
Alan Woods
PMA Customer Support
360-600-5695
