| gill | 02-17-2007 | comment profile send pm notify |
just got anew 38z with a 20 cell i have a few questions for you putz guys. i have been running schwings for 7 years so i have to get used to this rig, but whats the easiest way to clean the s tube. can you prime in a z config or not, and the same with sucking a sponge. just did first job with machine yesterday and when pumping flat out it had alot of surge when the s tube changed over even when umping slow with a slump of 4 inch. |
| bisley57 | 02-17-2007 | reply profile send pm notify |
When priming totally Z'ed you need to use a grout mix delivered from ready mix,but if you have section A up,section B down,and C and D straight out priming will not be a problem with slick-pak and such.Washing out is done with the machine cycling,,in forward or reverse,until the tube is clean.The particular truck you run is a real hog,you wont have any problem pumping any mix you fool with.The back end should have an auto greaser because the rear gland is very large,and requires alot of grease.Normal problems are with the shifting proximity swithches located on the main cylinders,or maybe the proximity switch distribution block right there by the brain.Learn how to cycle your machine by the stack valves,and practice with your intermitent switch,you will use it with funny loads.Also keep an eye on your accumulator pre-charge pressure by opening up on the dump valve slowly and watching where it spikes,should be 90 bar?Low accumulator pressure will give you a very "lazy"switch.The ring will take a little more effort to roll,I am sure you have access to a porta power,and remember,plenty,plenty grease.Remember a faulty grating switch will not allow you to pump,and always remember to set the parking brake,which will give you a red light if not done so.In time you will see these things, now on the other side I run a sch...... |
| Russ | 02-17-2007 | reply profile send pm notify |
I run a 36z Putz and I prime using just water. If you fill your hopper half full and pump it down before the concrete reaches the cylinders you most likely with not have a problem in any configuration. You can also use the prime a port to push water ahead of the concrete. Slick pack works good but creates a mess on the jobsite. |
| gill | 02-17-2007 | reply profile send pm notify |
bisley do you run one of the yellow and white pumps in the nawlins area |
| HFK Concrete | 12-13-1901 | reply profile send pm notify |
Hey shortbus, is that why they call you short bus. what if your inside a building? you cant always be in a frame. listen the best way to do it is this way. 1. cycle your pump in forward to 1 stroke every 3 seconds. as soon as you hear the s-tube shift shut your pump off. 2.do not put any water in hopper. 3. tell driver to fill your hopper with concrete, and do not turn pump on yet. wait. 4. fill priming port with your choice of prime. 5. now close up and turn pump on now you have prime>>>>air>>>>>and thn concrete going through system. if you do not have any gasket leaks, your concrete will never mix with your prime and never jam. |
| pumpit | 02-18-2007 | reply profile send pm notify |
i am certainly not claiming i know everything nor am i tring to start a fight but i would not take pumping advice from a lot of you guys some is good and some is bad i think for someone just starting with a new machine or new to the industy try asking one of the consultants there is a lot of nowledge there. everybody has there own way of doing it its up to you to use your best judgement P.S. dont waste your time water washing |
| mrmike36z | 02-26-2007 | reply profile send pm notify |
I prime in a Z everyday. With slumps ranging from 8 to 2.50. If you do prime a dry slump use more water in your hopper than usual. The secrete is going slow, I usually do it on a 2, if you don't when the concrete falls down 2nd section it gets ahead of the water.
Mrmike |
| gill | 12-13-1901 | reply profile send pm notify |
thanks for the info i have never been around a putz or a z boom |
| pudg | 09-15-2008 | reply profile send pm notify |
you can prime just like you do any other pump, I run a 38m putz 20 cell it is a beast,I usually dont prime in z but I have just go with what you feel comfortable with |
