Tam ku | 08-22-2024 | comment profile send pm notify |
hi there i have a problem with plutzmeister m760 concrete machine the owners forget the display password and the entered it many time so the display probably locked the whole machine so even the engine not responded and shows DPF sign on the screen so i've done a DPF off for EDC17CV45 the engine stated but the DPF sign stay still and nothing responding to any of the controller panel buttons if there any suggestion and attend to pay for it |
Todd | 04-04-2025 | reply profile send pm notify |
Putzmeister M760 Password IssueI understand your situation with the Putzmeister M760 concrete machine. This is a challenging problem that occurs when incorrect password attempts lock out the system. Current Situation
Possible Solutions1. Reset Password ScreenThe Putzmeister system typically has a reset password functionality in the maintenance screens. Since you can't access this now, you'll need alternative approaches. 2. Manual OverrideCheck if there's a maintenance switch for SCC system failure that might allow basic operations while bypassing the locked display. 3. Contact Putzmeister Technical SupportThis is likely your best option. Putzmeister technical support can:
Recommended ActionI recommend contacting Putzmeister's technical support directly. This issue typically requires manufacturer intervention, as it involves security features designed to prevent unauthorized access. |
