Todd | 03-16-2010 | comment profile send pm notify |
Cemen Tech and REED have joined forces to create the first ever MixerPump, a combined volumetric concrete mixer and concrete pump. For small jobs, the all-in-one MixerPump drives to the jobsite, then mixes fresh concrete and pumps the concrete wherever the contractor wants it to go. Contractors only need to make one phone call to schedule both their concrete and concrete placement, saving time and money. For larger concrete projects (see below), the bins of the volumetric mixer can be filled from the top by a loader for continuous batching and pumping more than 30 yards per hour (23 cubic meters per hour). |
Todd | 03-16-2010 | reply profile send pm notify |
The pump easily disconnects from the mixer whenever it isn't needed, then quickly re-attached when it is, providing a simple "ON/OFF" solution. The REED pump can be attached to mobile or stationary Cemen Tech volumetric mixers. A single power source drives both mixer and pump packages. The MixerPump can pump pea-gravel mixes, ¾" blend mixes, 1" big rock mixes, and even low-slump shotcrete mixes. The tapered underside of the volumetric mixer allows for ample storage of pipes and hoses. For more information about the MixerPump, call Cemen Tech Mobile Mixers at 515-961-7407 or REED Concrete Pumps at 909-287-2100. (or email mike.newcomb@reedmfg.com |
pump wrench | 03-17-2010 | reply profile send pm notify |
i'm curious how much wieght is on the drives when loaded and with the pump on it? |
Slinger | 03-18-2010 | reply profile send pm notify |
It looks like maybe a 7 yard box so with the weight of material, powder, water, calcium, and air entrainment, 35 ton would be a close guess. Not to mention the weight of all the hoses and clamps possibly closer to 37 ton. |
