Reed or Schwing line pump
440skidoo 05-07-2014
Looking to buy owner operated line pump let me know what you got? Willing to drive anywhere in US.
REEDPumps 05-07-2014
Hey there 440skidoo,
From your zip code on your member profile it looks like you're located with us here in California...if that is the case, you're going to want to make sure your pump's diesel motor is CARB Certified.
If you buy a NEW REED Pump, you can have that pump's "Tier 3 Flex Motor" CARB Certified.
However, if you buy a used pump (regardless of the make of the pump), they're not going to allow you to register that pump...
Please give us a call at 909-287-2100 if you'd like us to quote you on a new pump.
Thanks!!
Mike Newcomb
REED Concrete Pumps
www.REEDpumps.com
909-287-2100
DIGGER 05-07-2014
Give George Clingerman a call at Transcrete in Los Angeles, he will cut you a good deal on a Cal legal pump.
