Todd | 10-03-2014 | comment profile send pm notify |
DaveTPG | 10-03-2014 | reply profile send pm notify |
What's being used to do that? |
mudgator | 10-03-2014 | reply profile send pm notify |
Hey David, it's Jeff. Look's like the old pressure washer/blow out cap trick. Got me curious. |
ahssci | 10-03-2014 | reply profile send pm notify |
One dent in the pipe would screw you. |
Beast | 10-03-2014 | reply profile send pm notify |
I really need to know what did this , I have a months worth of work for them. |
I am with you Beast. Move the camera to the other end. WTF? |
block | 10-04-2014 | reply profile send pm notify |
It's very simple. But very dangerous I've done it a few times. Just hook any old pressure washer to a plow out cap and turn it on. The water goes around the old Crete because concrete shrinks as it gets hard. The only problem is a pressure buts out more psi then a clamp or the pipe is rated for So you don't want to b any where near it. I blew a clamp about 50 yrds across the yrd and it stuck in the side of a steel building. So...... |
shady rashed | 10-11-2014 | reply profile send pm notify |
this is may be useful for the double layers esser pipes because these pipes are very expensive. |
