replacing boom pipe
gillrod 1 01-19-2016
what is the best way to replace boom pipe. from the tip back or from the hopper out
Farmboy72 01-19-2016
Seem to have better luck going hopper to tip.
ShortStik 01-19-2016
all companies ive worked with do hopper to tip.
Dipstick 01-20-2016
Same here.. And often you will be surprised how bad it fits.. My theory is that the pipes will always be pushed a few mm away from eachother after a few poors.. So best use a jack to pull the pipes towards eachother when you can't get the clamps on..
ShortStik 01-20-2016
lol, come-alongs, cursing and smoking  good times
gillrod 1 01-21-2016
thanks guys, i have always done it hopper to tip also. iwas just wondering if that was the best way.
Beast 01-22-2016
hopper to tip has always worked best for me. also i would suggest getting the gaskets that have the spacer in the middle for your non swivel clamps , that little gap it leaves will make a big difference in the end.
Dipstick 01-22-2016
Indeed Beast it will make a difference but the pipes will even go a bit more apart when pumping under pressure. Just mentioning Wink
gillrod 1 01-22-2016
ok hanks
