| crete | 04-28-2016 | comment profile send pm notify |
Sooo I fire up my 2000 Mack Telebelt a week ago and it pegs the tach and start billowing black smoke. I tried to stuff the clutch in to get it into gear,key won't shut it off. By the time I tried to get a shirt or something into the air cleaner it locks up. At the Mack dealer now and they confirm the crankshaft seized. Turbo was not the culprit. All off the injectors were replaced about 2 days before it happened. No love from the dealer as they say the injectors are all still good. The next thing they are going to check out today it the ECM and pump. So now I'm looking at 25 or 30k for a new Mack reman. Anyone experience such a thing? |
| bisley57 | 04-28-2016 | reply profile send pm notify |
In the late 70s the diesel engines that ran our boat always had a means of choking the air intake if there was a runaway.A scary thing indeed,although handled properly damage will be minimalized.It is a very good thing you mentioned this old fact where some of these younger operators have never heard such a thing |
| wannadrag | 04-28-2016 | reply profile send pm notify |
Man that sucks although I have never personally experienced a run away, I did have a good conversation with a buddy about it. Only way to stop it is to stop the air or the fuel. A scary thought. |
| b-alto | 04-28-2016 | reply profile send pm notify |
Wow Terry that sucks! What the heck, the fuel must have stuck wide open? It sure sounds fishy since they just worked on the fuel system. I have never heard of such a thing. Maybe call some mechanics and ask if they know what happened . That dealer won't thats for sure. |
| crete | 04-29-2016 | reply profile send pm notify |
Exactly Got a new Mack reman engine coming, but it doesn't include the fuel system. So they have to test the pump and ecu for problems. Phone ringing off the hook and downed equipment. Very frustrating. |
| b-alto | 04-29-2016 | reply profile send pm notify |
Terry I talked to my mechanic buddy he said it sucked oil from the pan and was running off of oil wildly! He said they must have done something wrong and to call Mack . It sucked the oil out of the crank case and ran dry . |
| wannadrag | 04-29-2016 | reply profile send pm notify |
b-alto, exactly. I was working on a 7.3 ford that the turbo housing bolts had backed out, and in talking to my friend he brought up how the engine could run away off of motor oil being ingested by the turbo/engine. |
| pudg2 | 04-29-2016 | reply profile send pm notify |
I had a old 3208 CAT do this , had to choke the air intake luckily it didn't damage the motor , the problem was in the injector pump. |
He said it probably ran until the engine ran out of oil and seized the crank. My guess is oil getting into the intake through a o ring or leaking head gasket? It shouldn't have spun the crank just from high revs I wouldn't think. |
