| rusty22 | 09-01-2010 | comment profile send pm notify |
I'm a 35+year operator.I've run putz mostly.I was running a swang a few years back and the remote had the concrete pressure you were pumping displayed. I really liked the idea.The best thing to come out in years for safety.I had to put 5 2/1/2 in hoses on the end of the boom and could not see the hoses at all.I had delays in the mud service.But i could watch the display and see if it was going to put to much pressure to get going again.So why not a pressure shut off you can set???? |
| murf | 09-01-2010 | reply profile send pm notify |
So why not a pressure shut off you can set???? surely this is what you have output/volume control for , since the pressure becomes less of a problem if you have no volume behind it?? |
| Pump N00b | 09-01-2010 | reply profile send pm notify |
You CAN set the pressure, both accumulated concrete pressure and hydraulic pressure. |
| Vasa | 09-01-2010 | reply profile send pm notify |
I have it to , You can have it on modern Putzmeisters if You order it.... When You have learn to use it You dont want to operate one without .
It's like an air-cuff , once You started You wont go back ! |
| rusty22 | 09-01-2010 | reply profile send pm notify |
What i would like to see is one you can set.Like your first load pumped out of the boom our system.Say it's 100 bar, you set it to 125. If it goes over, it trips the safety.You have time to see if something is wrong. |
Ergonic for truck mounted concrete pumps |
| b-alto | 09-01-2010 | reply profile send pm notify |
Yeah it would be nice. I've often said small line pumping should be done with small trailer pumps. 275 bar max is too much. Bammm! Who wants to go see what happened at the other end. |
