| cifa k 35 | 05-01-2010 | comment profile send pm notify |
Some pictures show truck |
| cifa k 35 | 05-01-2010 | reply profile send pm notify |
| Tigger | 05-01-2010 | reply profile send pm notify |
what are those gray supports under the outrigger feet? |
| murf | 05-02-2010 | reply profile send pm notify |
its a pump unit for a swap body system, the grey supports are probably there as a safety item on a show stand, stops having a suspended body being sat there on its hyraulic rams alone with the public being near it. Interesting how the manufacturers dont fully extend the outriggers on the other pics!!! |
| Vasa | 05-02-2010 | reply profile send pm notify |
They have probably not space enough for the leg . But if the boom is inside the "square" of the feet it will stay safe . If I only put My leg down and unfold the boom to the rear it stand perfect , but not infront of the cab or to the side . Than it tip ower , it is a Putz 46-5
mmm, with 65m of boom poked vertical id have the lot out!!!! |
| lawrence | 05-03-2010 | reply profile send pm notify |
Its all mathantics do
you really think they would put somebody in harms way their? |
| Drew AUS | 05-03-2010 | reply profile send pm notify |
It is safe to do! Think about it like butterfly or suicide legs just in reverse! |
| 52putz | 05-03-2010 | reply profile send pm notify |
Couple things: Pretty ballzy to run the boom all the way in the air without at least the rear outriggers out. I don't care how you do the math. The hopper must be 6 feet in the air! The top of the rubber is even or above the deck! The blue pumpkit is interesting...if the last pick is the kit fully mounted to the truck, does it bring the front axle off the ground? Thanks for the pics! Interesting... |
| cifa k 35 | 05-03-2010 | reply profile send pm notify |
Greater openness of the stabilizers would be safer ... I do not think that CIFA and SERMAC jeopardize their truck ... |
