Schwing 2023-4 Rexroth pump
rusty22 06-12-2013
Anyone ever rebuild one of them.I can gt the rebuil kit.?????Undecided
gboom 06-13-2013
rebuilding a hydraulic pump is not something you can do in your garage, special tools are needed, you need to know piston tolerances, and finally you need to test the pump after the rebuild (a screwed up rebuild installed on your pump is a lot worse than a screwed up rebuild on a test bench)
take it to a hydraulic shop, that is famililar with Rexroth pumps, otherwise contact Schwing, sometimes it is cheaper to buy new
dlee7729 06-14-2013
Seals and bushings are all you going to get in a rebiuid kit. And that alone my not help you.Worn input shaft or rotor group and the rebiuld kit is useless. Buy new or rebiult and send the core in .
