Schwing 31HT/XT vs. Putz 31-5 ???
16 CELL 09-13-2011
Would be interested to hear the pros and cons of each machine as well as the advatages of one vs. the other from those have been are fortunate enough to run both.
N.D.Fuccillo 09-16-2011
I haven't run either one, but I imagine that a 4 section boom that telescopes in and out would be much easier to run then trying to configure 5 small sections in crazy set ups.
FunnyBoom 09-17-2011
I have only ran the Putz but I will tell you the customers had used both and told me they preferred the Putz over the Schwing. Of course it couldhave been allin the operator alos ;-). Now that doesnt say anything about the operation of the unit but it does speak volumes beacause you want to make the customers happy. The Putz 31z is a sweet machine. Probably my favorite to run out of the many of pumps I have had the pleasure to run.
16 CELL 09-17-2011
I have not run either machine, it seems to me that the Schwing boom would be less complicated to operate and I do like the fact that it also has 540 degrees of slewing which would minimize the chance of showing up on the job and not being able to unfold because the boom is wrapped around the wrong side of the truck. On the other hand, I really do like the Putz. S-tube and 16 cell pump kit (lots of pressure), and the Putz seems to be more operator friendly in terms of storing hoses with it's nice low decks. How complicated is this boom to operate in comparison with a 5 section RZ ?
I would really like to hear from anyone that has operated either of theses machines, especially regarding which outrigger configuration they preffer (Putz. has swing out rears, whereas Schwing uses telescoping back outriggers)
big lance 09-17-2011
i have been running the 31 schwing for almost 7 years with bbcp and i love it so much you can do with little room and also fast break down and setup.
schwing for outrigger way better set up in confinde spaces like ally way with dumpster and power poles most times you can find a way to get them out all the way to get the job done safe
Drew AUS 09-20-2011
16 Cell if the boom is closed on the wrong side it doesnt mean you cant do the job!! Its happend to me plenty of times all I do is find somewere to put the legs straight down lift the boom veritcal and put it on the other side.. Problem solved!! It might take 10mins to do but the job gets done !! I think a lot of ppl forget 9 out of 10 times theres a way to do the job safley you just have to think about it more..Wink
16 CELL 09-20-2011
I realize that, and believe me, have done so many times. What I am getting it is that it's much more time efficient not having to spend the extra 10 mins to spin the boom around off-site.
