shrek52z | 12-14-2009 | comment profile send pm notify |
shrek52z | 12-14-2009 | reply profile send pm notify |
I meant 52z |
Todd | 12-14-2009 | reply profile send pm notify |
nice looking pump. How many tarps do you use? |
Telealbelt | 12-14-2009 | reply profile send pm notify |
Now thats what I'm talkin bout. Beauty Shrek52z |
its just two 10x20 for the hopper and a 20x30 for the rest. And about 15 clamps to hold it all down. |
Boom Inspector | 12-14-2009 | reply profile send pm notify |
those are very nice pumps shrek, good job at using the tarps. I know they must be a pain to use but it helps with clean up |
putzman1975 | 12-14-2009 | reply profile send pm notify |
nice job on having a clean pump how can u tell if water box is low or hyd oil leak |
pudg | 12-15-2009 | reply profile send pm notify |
how can you tell if the water box is low ? you look its not like you could see it through a sight glass, now the hydraulic leaks, well we tarp all our trucks the same way its just one bad point of using tarps but there is so many good points you just kinda gotta live with the few bad ones. |
pumper chuck | 12-16-2009 | reply profile send pm notify |
watch temp gauge... |
ShortStik | 12-16-2009 | reply profile send pm notify |
hehe. too much man, too much. that will keep er clean but your covering up alot of what you should be able to see on site pumping. |
shrek52z | 12-17-2009 | reply profile send pm notify |
That is one of the down falls just like pudq said. I have been tarping pumps for 8yrs and every so often go look under the tarp I make time to check the pump. |
