Niall | 01-09-2018 | comment profile send pm notify |
Hello,everyone, I drained the hydraulic oil from my Schwing 305 changed the hydraulic filter and refilled the tank but now the S tube slewing rams wont work but the main piston cups and agitator are working just not the slewing rams. Is there a way to bleed the air from the system or have i done something wrong, Any help would be greatly appreciated |
T-Riffic | 01-09-2018 | reply profile send pm notify |
maybe loosen the hydraulic lines on the outside of those slew Rams. With the engine off there should be enough pressure on the system with just a full tank of oil to push the air out retighten the lines once you get oil |
Niall | 01-09-2018 | reply profile send pm notify |
Thanks very much for the fast reply, Got it sorted in the end, very surprised with the amount of air that got into the system, Thanks again, much appreciated |
