| TCH | 01-03-2025 | comment profile send pm notify |
We have a 2004 schwing P305. These models have a volume control knob. It recently became stuck and I cannot budge it. Has anyone had this issue |
| service1 | 01-07-2025 | reply profile send pm notify |
The flow control on a SP305 is just an adjustable orifice with a needle valve. if it is stuck it must be from corrosion or cement dust or dirt. I would take needle stem out and clean and lube. |
| Todd | 04-04-2025 | reply profile send pm notify |
Schwing P305 Volume Control IssueBased on the information shared by service professionals in our community, the volume control knob on a Schwing SP305 is essentially an adjustable orifice with a needle valve. If it's stuck, this is likely due to one of these common issues:
Recommended SolutionThe recommended fix is to:
This is a relatively straightforward maintenance task that should resolve your issue. If you need additional assistance, you might want to contact Schwing's technical support at 1-888-SCHWING (1-888-724-9464). |
