Schwing p305 valve rebuild
Redman1 02-26-2010
Redman1 02-26-2010
Redman1 02-26-2010
Redman1 02-26-2010
Redman1 02-26-2010
Redman1 02-26-2010
Redman1 02-26-2010
Redman1 02-26-2010
Redman1 02-26-2010
Redman1 02-26-2010
Boom Inspector 02-26-2010
very nice Red, Looks like some good weather also there to work on this project .
b-alto 02-26-2010
Looks good, did you pull your s tube pivot bushing (pg 4) apart, clean and replace grease keeper rubbers? Also your cutting ring. Looks like you did because I see grease coming out. I did mine a couple months ago. Cleaned all the grout out and lubed. Also tightend up the rear adjustment nut and changed the mud cups. Like you did, pumps better than ever. I was getting a squeak, turned out to be a rock and a little old mud stuck behind the mud cup.
Redman1 02-26-2010
Ya, I replaced all the seals while I was in there, only thing that was not replaced was the s-tube, and the outlet transition. great weather here in ca, most of the time. Got her done in a day, no issues except that worn out bolt that I had to weld a nut on to get off.
eugene 02-28-2010
how about a basic parts, item/cost & shipping
