Schwing rams
dlee7729 02-07-2013
39m schwing. 9" rams. Every year it's the same story since the pump was new. First time it the temp goes below freezing the rams leak .
Ti-so 02-07-2013
It did just the same on mine i taught it was because they were getting old.Put brand new two weeks ago and no leaks since then.My old rams were 10 month old ,900 hours ,2000-2500 sq meter pumped.
rusty22 02-07-2013
Don't fill the water box past the bottom of the ram seals.Year round
Dipstick 02-07-2013
Specialy over night i've heared. Our putz guy says if you start pumping and the seals are stil cold you don't want water there. Always have the level in the water box below the seals..
Mister_Perkins 02-08-2013
I just changed my cups, they were leaking quite a bit ...
Dont need one 02-08-2013
 Try hot water in the water box, let things warm up.
 Depending on your yearly yardage, that might not be bad.
dlee7729 02-13-2013
Changed out the rams , diff packing , and scraper. New rams and packing logged in at 325,790 yds since new and 19,253 on the changed out rams.
